To be honest I’ve no idea, there’s no manual, looked for one online but can’t find one. Element is fine. So, it’s a double oven, each oven has a top & bottom element, the one that wasn’t working was the bottom oven bottom element, it gets hot for a minute, then says HHH & starts cooling. So I swapped the above part with the bottom oven top element one & the fault swapped over between ovens so I can’t see why it’s not that part. Also it’s a Chinese firm from what I’ve gathered so not even a technical line I can phone for some assistance re what the HHH stands for.Does the hhh mean that a safety overheat has tripped?
Have you dead tested the element at all?
What Brand is the Oven ??To be honest I’ve no idea, there’s no manual, looked for one online but can’t find one. Element is fine. So, it’s a double oven, each oven has a top & bottom element, the one that wasn’t working was the bottom oven bottom element, it gets hot for a minute, then says HHH & starts cooling. So I swapped the above part with the bottom oven top element one & the fault swapped over between ovens so I can’t see why it’s not that part. Also it’s a Chinese firm from what I’ve gathered so not even a technical line I can phone for some assistance re what the HHH stands for.
