CompEx 01-04 (Failed Ex04) | on ElectriciansForums
Discuss CompEx 01-04 (Failed Ex04) in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Middlesbrough
I sat the CompEx 01-04 course for the first time back in July. The results came in the post on Saturday and I have failed 1 of the 5 units -
Ex04: Inspection and maintenance of Ex i systems
Quite relieved if I'm honest as the installs are quite intense!
Does anyone have any tips for the inspection of Ex i systems? If I can remember they are looking for visual, close and then detailed inspection. I think it is required to find 5(ish) faults on each type of inspection.
Thanks.
I did my 5 year refresher about a week ago. Don't know if I passed or not, should find out soon.
I think for ex i inspections
Visual - enclosures should have blue is labels, damage to cables etc, missing blanks etc, ambient temperature correct for apparatus, equipment correct for zones.
Close - basically use the documents to check equipment is correct for the gas group, equipment manufacturers are correct, glands match specification etc.
Detailed - open the panels up check for loose connections , damaged or incorrect terminals, segregation of i.s and power circuits. zenner barriers round the right way, check terminations match drawings.
Make sure once you find a fault, or once you've found all the faults for 'close' etc you need to write down beside them what number on the inspection sheet they have failed.
Hope that makes sense, I've just switched to nightshift and my head is up my arse but If I think of anything else I'll post it up later
Chris
Upvote 0
With 'Intrinsically Safe' keep an eye on the IS earth to make sure it is clean.
From memory they always have an IS barrier turned upside down.
Eg - Non IS circuit connected to the IS side of the barrier.
Most guys do struggle with this part of the course.
What centre did you take it in?
Upvote 0
Are there not model inspection forms in your training material/toolbox guide?
It's not normally that tricky.
Is everything wired as per the drawing, have they used the wrong make/model of components. Is the screen wire grounded as per the drawing. Are spare cores grounded. Have they got IP washers and earth tags where they need them.
Upvote 0
Hi My name is Jimbo, I'm struggling with the revision for my resit exams for Compex inspection Ex 02 power and Ex 04 IS inspection. tomorrow I'm getting old and tired so any help would be very much appreciated > I see you had some notes on the subject.
My e-mail [email protected]
Many thanks and kind regards
Jimbo
[/QUOTE]
I've got a few sets of notes on it if you PM me your email I'll try and look some out for you.
Upvote 0
Reply to CompEx 01-04 (Failed Ex04) in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi there, is there anyone who can help me with the Compex Ex 01 - 04 notes/study guide book please. As I'm about to go for my assessment in 2...
9K
Not sure you will get a reply they haven't been on for over a year.
5K
Can you share with me all notes I really need that
19K
Dear Gents, I am writing from Qatar. I hope you are fine. Do you have any experience about Ex inspection done at field. I need to inspect my...
6K
If so, they are registered with THE BIGGEST SCAM OF THEM ALL.
11K
Electrical Courses
