View the thread, titled "Compressor blowing 13 amp fuse" which is posted in Commercial Electrical Advice on Electricians Forums.
Contact Machine Mart Technical advice either by Email, phone or fax
FREE Technical Advice, 6 Days a week
Monday to Friday 8.30am – 6pm
Saturday 8.30am – 5.30pm
Tel: 0871 410 1260
Fax: 0871 410 1265
Email: [email protected]
I bought a 3kw log saw from machine mart a few years back, that came fitted with a 13A plug, which obviously kept blowing!
I e-mailed them and they eventually conceided that it needed to the changed for a 16A plug, which they supplied FOC.
Sorry to drag up an old thread!
Rich
I have had the same problem the answer was the non return valve. There is a nut on the valve this houses a spring and a thick rubber disc. This had stuck open causing the compressor to start under load. Cleaned and replaced problem solved.
Yep, thats your problem the NRV (non-return valve) it was stuck or if the compressor is old sometimes/most cases only the spring is presented and no sign of pastel (the rubber thing). There are service kits for these valves or a new valve (£20-£25)
Reply to the thread, titled "Compressor blowing 13 amp fuse" which is posted in Commercial Electrical Advice on Electricians Forums.
