concentric cable ??? | on ElectriciansForums
Discuss concentric cable ??? in the UK Electrical Forum area at ElectriciansForums.net
T
tom79bmth
Hi all
Just a quick question what is the bs name for concentric cable that the db use for tncs and what size do they usually use on a single house thanks
Reply to concentric cable ??? in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
No, that is part of a different earthing system, don't mix the different earthing systems unless you have given proper engineering consideration...
davesparks
