concentric cable ??? | Page 2 | on ElectriciansForums
Discuss concentric cable ??? in the UK Electrical Forum area at ElectriciansForums.net
T
tom79bmth
Hi all
Just a quick question what is the bs name for concentric cable that the db use for tncs and what size do they usually use on a single house thanks
If you have a look at cable manufacturers websites and search for concentric cable they will usually identify the appropriate British standard.
However since cables are covered by a variety of standards such as BEN60228 for the design of conductors for cables and BSEN60811 for test methods for insulation there may not be only one standard applicable.
The one I have just found as being the most commonly referred to is BS7870.
To be honest, i've only ever seen 35mm concentric being used by the DNO for domestic, small commercial installations. They tend to purchase a one size fits all for these installations, and as stated 35mm aluminium is the going size for a 100A supply... Though looking at the cable dia, it could be easily be excused for looking like a 16mm cable... lol!!
No, around here, which is WPD, it's definitely 16mm Al with Cu spiral. I've got some, and I've also had to work with it on DNO kit that's transferred to private (don't ask).
Well i wouldn't feel happy with a 16mm Ally concentric or split concentric cable with a 100A BS 88 protecting it. A 60A fuse i probably wouldn't be too phased about!! lol!!
Maybe that's also why they only fit 80A fuses, who knows. They seem to make it up as they go along anyway!!
WPD standard for single phase TNCS supplies up to 100 A is 25 mm hybrid with aluminium core phase conductor with copper concentric neutrals.
It could be 400A fuses in the sub station "protecting the cable" The assumption is the service cable will burn open circuit in the event of a fault. Substation fuses do not protect cables they are there to grade with the HV protection for the local TX.
Reply to concentric cable ??? in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
No, that is part of a different earthing system, don't mix the different earthing systems unless you have given proper engineering consideration...
davesparks
