Concentrica cable | on ElectriciansForums
Discuss Concentrica cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
For a sub main you’ll need split concentric cable where the earth and neutral are separated. You can’t use concentric. Split concentric it nice to use.
Let's hope you can make a good job of making off the ends, They can be a real pig of a job to make them look anything. The best way i know of, is to use a 3 spout heatshrink breakout, and heat shrink tubing for the Neutral and earth tails....
Reply to Concentrica cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Many thanks. Very clear!
Use wago connectors instead, much easier and safer I think
