Concrete channelling | on ElectriciansForums
Discuss Concrete channelling in the Talk Electrician area at ElectriciansForums.net
G
GT1
Pricing up a job soon whereby I need to provide cooker supply to a kitchen "island".
The floor, sadly, is solid concrete and will have floor tiles over the top.
Not sure about the distance involved but I wanted to ask if anyone else had done something similar.
I'm thinking channel out the concrete with a view to the tiler either tiling directly over the top or screeding over the entire floor prior to tiling.
Any input appreciated.
PS
I'm hoping my SDS scutch chisel will be up to the channeling ??
If its going to be hard work
Get a builders moron ( they all have one ),they work well,cost little, and they believe you, when you tell them its a doddle
Done a few of these... you've got a few options:
SWA
Copex
Conduit
Good luck with the chasing, u wanna pop down your local hire place and get out a hilti chaser (or similar) cost around ÂŁ30 for the day but well worth it....
[ElectriciansForums.net] Concrete channelling
We use a chasing machine....2 diamond blades which cut 2 slots,then just chop out the middle.Quick,neat and connected to a vacum cleaner,absolutely no mess.......probably hire-able.
It's all very much in the planning phase at the mo, although fairly imminent if it's a goer. not sure about the sink at the mo, although I'm assuming Im going to be putting the circuit on rcd protection anyway.
Would a standard wall chaser be up to the channelling work if it's got the appropriate blades ?
My feeling is that it needs something heavier ?
So...
Not too much a problem about the channeling in the floor.
I can clip direct to the concrete floor because the level of the floor will be raised above it's present level due to the wet underfloor heating system. !
Looking like 10mm T&E at this rate due to the heated floor. !
Reply to Concrete channelling in the Talk Electrician area at ElectriciansForums.net
Rather than covering the issue, find where the moisture is coming from and address from that end, is the outside ground level above the inside, is...
Which truly is the Number 1 Best Tile Adhesive Brand? Since 2007 Tilers Forums started an annual best tile adhesive Poll and sent it out to the...
