Concrete channelling | Page 2 | on ElectriciansForums
Discuss Concrete channelling in the Talk Electrician area at ElectriciansForums.net
Well as ever. The plan changed. !
Channel has been cut in the floor ready for electric under tile heating going over the top of my cable.
The floor max temp is only 30 deg c so I see no reason not use standard flat twin and earth. (derated capacity).
Anyone had a similar job ?
Reply to Concrete channelling in the Talk Electrician area at ElectriciansForums.net
Rather than covering the issue, find where the moisture is coming from and address from that end, is the outside ground level above the inside, is...
Which truly is the Number 1 Best Tile Adhesive Brand? Since 2007 Tilers Forums started an annual best tile adhesive Poll and sent it out to the...
