Condensation on a bathroom extractor fan | Page 2 | on ElectriciansForums
Discuss Condensation on a bathroom extractor fan in the UK Electrical Forum area at ElectriciansForums.net
tex431
Outback, NZ
Hi got a customer who has a icon 45 bathroom extractor fan, fitted by myself and it develops water droplets on the front grill and drips on the floor. It is flush mounted in the wall through a 40mm polystyrene backed plaster board. I have put some expanding foam between the wall and the back of the plasterboard. Due to the nature of the wall I put a duct through the wall 150mm long, sloping out with a back draft flapper on the wall no water runs in the duct, it only forms on front grill. Any suggestion? Probably going to swop fan to a different brand. Never had this problem with this particular fan before
I have seen similar issues in timber framed houses with a membrane in the walls , dampness and mould issues especially in cupboards and closed voids , The customer will need some sort of ventilation system in use together with heat recovery combined ..
Amazon.co.uk: Manrose 4 Inch Backdraft Shutter: Explore similar items
www.amazon.co.uk/Manrose-4-Inch-Backdraft-Shutter/sim/.../2
Backdraft shutter 24 Oct. 2013. Reviewer: Mr L R Dubery (see more about me) It is ok but and it is a big but the spring is far to week requires another one to work ...
this should work if you fit it in the ducting, will stop the cold air traveling through the duct and meeting the warm air and causing the condensation.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Reply to Condensation on a bathroom extractor fan in the UK Electrical Forum area at ElectriciansForums.net
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
Thanks for your advice guys. very helpful
