Condenser tumble dryer help | on ElectriciansForums
Discuss Condenser tumble dryer help in the Electrical Appliances Forum area at ElectriciansForums.net
Superman
London
Hi everyone, happy new in advance to you all. Wondering if you guys may be able to help with my faulty dryer. My dryer was not spinning anymore and after Googling/YouTube found out the belt has snapped…replaced it with a new belt today BUT now for some reasons it keeps tripping the fuse box every time I press the start button…..any ideas the possible faults or fix? It was definitely powering up before I opened it up to check the belt.(see pic of the tumble dryer I have)
  • [ElectriciansForums.net] Condenser tumble dryer help
Did you have to disconnect any wiring to get the new belt on?
If no, then there may be a trapped wire under something you've removed to get the belt in, or the new belt has rubbed against some wiring
I did remove wire labelled 1 to get the new belt around the drum….was trying to remove wire labelled number 2 but it was just not coming off so left it and managed to get the belt around the drum somehow.[ElectriciansForums.net] Condenser tumble dryer help
Reply to Condenser tumble dryer help in the Electrical Appliances Forum area at ElectriciansForums.net
I well remember the sliding windows on ther Mini, and also the manual choke and the foot-operated dip switch. I recently traded in my 18 year old...
    • Informative
"Value engineering."
2 3
5K
