Condensing extractor fan | on ElectriciansForums
Discuss Condensing extractor fan in the Electrical Tools and Products area at ElectriciansForums.net
littlespark
Staff member
Supporter
Patron
Solutions
Scottish Borders
Is there such a thing?
Just a standard bathroom, but can’t get through a wall or take out a window.
Are there specific condenser fans, or just use a normal one and fit a normal condensation trap and block up the end of the duct?
Been presented with this issue myself before littlespark…..at the time I left it as I had no idea, but was wondering if something like the trap in the link above could be used and then the moisture redistributed/directed in to waste water pipe somewhere much like a condensing boiler…..only a theory and not something I’ve ever attempted or looked into to deeply….🤔
You get condensation traps for a regular ducted extraction system…. For when the moist air cools and can’t be forced out as air….. but that’s only a fraction of the air.
I’m needing all of it to condense.
The homeowner thinks it will work, and really only needs me for the electrical bit.
I’ll just let him get in with the ducting part.
It’s only a small shower room, with a sash and case window on street side (2 floors up) but council won’t allow either a window fan or coring through and putting a vent on the wall.
Their suggestion was a vertical vent through the roof.
I don't think such a thing exists. Can you not fit a vent in the soffit, or take out a roof tile and replace it with a roof tile vent?
Ahhh
ahhh I see, in that I case I always vent my fans through the roof when possible, roofing merchants will sell ya a tile/slate to match existing with fittings to attach flexi etc to……I just hung a roof monkey a drink and up they go…..much easier than drilling 110mm holes 👍🏻
Condensation trap piped back to the waste for the basin or shower or even into the soil stack perhaps? or at a push into the WC cistern.
WFMLNC.
Looks a good bit of kit, just dubious about its ability to extract the amount of condensation associated with excess showering, would suggest a powerful extractor and a humidistat to control the motor, I have the Manrose humidistat that has a timer as well, find that by the time I have wiped down the shower not only has all the condensation gone, but I am also mostly dry, this is the extractor I fitted: 4"/100mm In Line Duct Extractor Fan - Silent 250m3/hr | Soler_&_Palau (5211360600) - https://www.tlc-direct.co.uk/Products/SLTD250SILENT.html and it lives up to it's name of silent very quiet compared to others.
Get what you pay for I guess?
I bought some Anti condensation paint from a place in Bristol when I was working away over there. The walls feel a bit warmer to the touch so nothing seems to settle on the walls when cold
PIV doesn't extract - positive input ventilation pushes air through the home and helps prevents condensation from forming.
The advent of hermetically sealed homes have made this sort of ventilation almost mandatory, it's all a compromise in the end due to needing air in to circulate, this is all standard practice in new builds now days, including heat exchangers on bathroom/Kitchen extracts, the amount of ducting in the loft of these so called passive homes can be quite extensive, easier in a single story dwelling, but difficult to retro fit in a older property, I did try extracting some heat from our wood stove chimney and ducting it too our bedrooms, worked to a certain extent, but in the end not worth the effort.
This may interest you: https://www.leroymerlin.fr/produits/chauffage-et-ventilation/vmc-et-extracteur-air/
PIV isn't generally difficult to retrofit as it would supply a single point in the average 3 bed house - typically the landing.
I have 'silent' humidistat fans in bathrooms and have been pleased with their effectiveness, but have been thinking of adding a PIV unit as I like the idea of forced air to all rooms.
Reply to Condensing extractor fan in the Electrical Tools and Products area at ElectriciansForums.net
Hi everyone, If you are looking for reliable EV chargers, check out our top-rated selection at E2GO! ⚡ Please note that all EV Chargers and...
    • Friendly
You could change it for a fan with a pull cord on/off switch, with or without a timer. It might even be possible to retrofit a pull cord into your...
Which begs the question, where does the second brown wire come from?
