Condition report using easycert | Page 2 | on ElectriciansForums
Discuss Condition report using easycert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In this situation I use the PIR report not the domestic EICR report format. When you add a page here you get a different section at the top of the page. Headings like location of Du, designation, fed from, OPD etc. In the scenario I would write in that the board is fed from xyz size tails and a henley block etc.
Does that help at all?
Reply to Condition report using easycert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
As it was explained to me, you can write anything in the book so long as it already exists in the book somewhere in original print. Tabs, etc are...
