Condoit bending | on ElectriciansForums
Discuss Condoit bending in the Electrician Talk | All Countries area at ElectriciansForums.net
Hi guys,
I was wandering how much conduit bending do we do these days?
Do we do some complicated ones or only 90* and 45* ?
Thanks!
Plastic - bending springs.
Galv - A Hilmor Shortie, stocks and dies, file and a reamer. If you intend doing lots of galv work then a REMS amigo will be your best friend.
finished a job earlier this year, 6 months doing 25mm galv tube all surface, 90's, sets, double sets, bubble sets the lot. Hall stock and die, hacksaw, file, whiteboard marker pen, tape, file, grips, level holesaw and you are pretty much sorted. I love a bit of tube. Doing sexy tube is an art, you must be at one with the bender when you acheive bendlightenment you will be able to levitate like yoda and bend 25mm tube round your neck metres off the floor.:D
i think youve missed trefolex, set square, reamer and a good eye...........
but i must agree, its a nice feelin lookin at a well bent and hung bit of tube, that youve done, takes practie though!!
For Galv i simply do this
[ElectriciansForums.net] Condoit bending
Now thats a good idea, I never thought of a whiteboard marker :)
also a chalkline is usefull,
Richard
Hi guys,
Thanks!
And remember the most important bit of conduit is your first bit!!!!!!! (galvi ) you will have a former with prob at least 5 marks on it!!! pick your mark bend a perfect 90 to a size you want then see how far you are out then adjust your sizes to suit!!! as for bubbles 45s and 90s easy ma biggest trouble always comes with the double 90s got them down to a tea now but had a few trophys!!!
Trophies.....
down south we call them a grave yard :)
Im on my knees praying I Dont get offered a job requiring anything but straight conduit I cant remember last time I did conduit its like reversing a trailer a bit of a Blackart
Reply to Condoit bending in the Electrician Talk | All Countries area at ElectriciansForums.net
T
Is this bend in a PEX pipe too much? Hi, I by chance discovered that amongst a bunch of copper pipes, I have a PEX pipe that runs through a void...
techweb
T
To start with the power companies don’t supply the equipment ground, that’s where the ground rods come into play. # 6 wire is required for the...
