Conductors in parallel...... | Page 2 | on ElectriciansForums
Discuss Conductors in parallel...... in the UK Electrical Forum area at ElectriciansForums.net
kingeri
Yorkshire
I was at a job on Friday in a big 4 storey house. One of the jobs I was there to do was to add sockets to a bedroom which actually didn't have any at all. The top floor sockets were on there own breaker, a 32A RCBO actually. There were two 4mm^2 T&Es at the RCBO so I initially thought it was a ring. When I found the other ends of these cables in the top floor loft area, they were both terminated in a junction box and a 2.5mm^2 ring was run from there. So, a lollipop circuit with conductors in parallel forming the initial feed (the 'stick' of the lollipop). I actually didn't have time to start the sockets so I will be there tomorrow to do it.
I am interested to know who would leave the circuit as it is and just add the sockets to the ring part of the circuit, and who would convert the circuit into a full ring (easily done with an extra JB next to the existing one). The last option would obviously result in a ring with 4mm^2 legs of equal length and the 'loop' section in 2.5mm^2. Thanks!
Sounds like a hybrid/ring circuit where you may have as an example ,an old 6mm twin that was used for a cooker circuit, then a ring final is ran from the 6mm , all connected in an contactor or isolator fed from a 32mm OCPD
I would leave as it is, just a personal preference but I don't like ring final circuits made up of conductors with differing csa.
I know what you mean. I think I might use one 4mm^2 to serve the existing sockets in bedroom 1 as a 20A radial and use the other to serve my new sockets in bedroom 2 and on the landing on a second 20A radial.
Reply to Conductors in parallel...... in the UK Electrical Forum area at ElectriciansForums.net
Yup will do exactly that when I'm back down there. Thanks for the help
Thank you for the speedy response! Have seen them on top of plaster in steel conduit before but guess it's not a common desire to have wires...
