Conduit Threader for drill | on ElectriciansForums
Discuss Conduit Threader for drill in the Australia area at ElectriciansForums.net
B
brizospark
In the wholesalers today the manager said he had seen an attachment for a battery drill that will thread 20 / 25mm steel conduit
Has anyone seen these or know where to get hold of one?
That sounds like a dangerous recipe for an otherwise simple task to go very wrong!
Die stocks!...with a bit of effort behind em..and theres tecknique of course..as above half a turn on then half a turn off to break the cutting.......and a good cutting paste/fat helps....
Most battery drills do have a switch on them that reverses the direction
i know,but you need an auto reverse forwards/back/fowward/back. ....... can't beat a stock and die. not like you're threading 2 ft. of it.
Would save some considerable time if something like that was introduced, to be fair though it takes a couple of minutes to put a thread onto a bit of galv, also gives you a bit of a workout
Reply to Conduit Threader for drill in the Australia area at ElectriciansForums.net
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
