J
john h owen
How did u get trained to bend a offset say a 20mm steel conduit?
Discuss conduit work in the Commercial Electrical Advice area at ElectriciansForums.net
best person i ever seen with steel conduit was my dad he could tube to or around anything,
when i was a lad we were doing a boilerhouse we had to tube out of the trunking down to the floor,about a metre across, then 6" set up on to plinth then another metre then right angle upto the isolator. he took the measurements wrote em down then took 1 lenght of conduit and proceeded to bend with no cuts and threadb it ,while i fixed saddles,once finished he gave it to me and said fit that!
to my amazement i put in place tightend the bushes and saddles and that was it magic!!!!!!!
Look on youtube there is a demo on how to measure & bend conduit by poly friendshu
One of the best ways to learn how to bend conduit and work with metal containment systems is to be on projects where this is the main means of distribution of the electrical installation. Working with those where bending conduit and fabricating trunking and traywork is second nature.
You need these skilled tradesmen to not only learn how to work with metal containment, but it's limitations of what you can and cant do as far as final wiring of these systems. It's no good having a neat pristine conduit run, that is impossible to wire!! ...And i've seen that a few times. ...lol!!
Most of the practical installation work, during my training was metal containment systems, that and heavy cable installations. I can still put my hand to it now, and often offer to help a tradesman on site having problems with a particular set he needs to get in. I think once learnt, it's something you don't forget, even if you do cock-up the first attempt!! ..lol!!
As far as I know, the Americans use different gauge conduit to us, it must be much smaller to be able to use a hand bender...unless all American sparks are bodybuilders too. Try doing 25mm with your hands!.Its using a American hand /foot bender I think on U Tube, not our UK bender unless I am wrong and they sell them in this country.
An old boy showed me how to make a sledge out of 20mm Galv.outstanding bit of work.could have done wi a couple of boxes to get the wires in tho.
Reply to conduit work in the Commercial Electrical Advice area at ElectriciansForums.net
