Conduit **** | Page 2 | on ElectriciansForums
Discuss Conduit **** in the UK Electrical Forum area at ElectriciansForums.net
LeeH
Lincs
Working in a factory which has a spec of conduit. Up to 50mm conduits all over the place with very little forms of other containment.
No idea why, but a nice steady job for the outfit doing it all.
[ElectriciansForums.net] Conduit ****
Is that in a cereal factory, spent a few years installing 2 inch tube. Use hydraulic bender and pipe threader with conduit dies. Had to measure the piston length to keep all the bends the same.
You can get 70 X 1.5 singles down 1 tube
Near Trafford Dave?
You would think there would be a much easier alternative that all that pipe work, I wonder why it wasn't done with tray or something.
Yes there is always an easier alternative, but that doesn't make it better or even suitable.
I'm sure someone had a very good reason for spending goodness only knows how long doing that pipework when they could have done it in trunking in maybe a quarter of the time.
Maybe it needs the impact resistance or good screening of each bunch of cables that conduit provides?
Reply to Conduit **** in the UK Electrical Forum area at ElectriciansForums.net
And if it's a garage then use metal clad accessories.
ok cheers for the help lads
