Connecting a fan to shower power | Page 9 | on ElectriciansForums
Discuss Connecting a fan to shower power in the UK Electrical Forum area at ElectriciansForums.net
T
tirfor
Hi all, a newbie requiring advice.
I have been asked to fit a fan within a bathroom with the following constraints:
1. fan needs to work in daylight when light is off.
2. ideally on a timer so steam can be removed after showering.
3. humidistat not to be used as past units did not work to well.
4. be able to use 3a fans.
5. cheap as poss so no expensive fans or expensive pir's
So i have thought it would be best to connect the fan to the showers power.
My question is:
1. Is this ok to do or is there a better idea?
2. A timed fan requires a live and switched live, so is a fused spur available with twin fuses?
3. My idea is to tap into the supply side of the shower switch to provide the live feed and then tap into the load side of the shower switch to provide the switched live. Both lives will go to separate fused spurs (located in assessable attic) then both spurs will be connected to an isolation switch (in wall be bathroom door) then of to the fan. Is this ok or am i missing something?
Cheers for your help.
can i take over from glenn
1is this person an electrician
2 he asks a question then sticks to what he thinks is right and what he said in the first place
3 why do you lot bother with this kind of thing:ack2:
Oh for God's sake man ...we have more important things to do than start f annying around counting the number of times the word F AN has been used!!
Shout at me as much as you like but I knew you would end up secretly counting them all :sifone:
no, glenn is a bit like the highlander....."there can be only one"...Plus I think 2 of Glenn would drive Marvo from drink onto hard drugs....
Feel free mate
Reply to Connecting a fan to shower power in the UK Electrical Forum area at ElectriciansForums.net
Rcd protection?
Many thanks all for the advise and suggestions. I’ll give the client the option of extractor fans
Recommended Sponsor News
Hi everyone,
