Connecting LED to 12V battery | Page 2 | on ElectriciansForums
Discuss Connecting LED to 12V battery in the UK Electrical Forum area at ElectriciansForums.net
L
Laurynas
I believe this should be easy.. Bud I have no Idea.
How can you connect LED to 12V battery? I heard that you have to use a diode and resistor, but how can you explain what is what?! Please I need details.
Basically, 470 ohm resistor has done its job.
I took information about 5mm red LED from data sheet, and then just calculated the resistance I needed. It was actually easier than i thought :)
Thanks guys :)
Tony - Your are real help! :)
Thanks guys :)
You're damn' right he is !!
Tony has more knowledge than you and I combined will ever hope to have !!
Reply to Connecting LED to 12V battery in the UK Electrical Forum area at ElectriciansForums.net
The company Liteplan do replacement modules: Liteplan – The UK's largest emergency lighting component supplier. - https://www.liteplan.com/ This...
Hi all, I have a couple of questions I'm hoping you can help with. I have put a solar panel on my kids play house which charges a 12v battery. I...
