Connecting main protective bonding conductor into MET thoughts | Page 2 | on ElectriciansForums
Discuss Connecting main protective bonding conductor into MET thoughts in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Reply to Connecting main protective bonding conductor into MET thoughts in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
