Connecting rigid conduit to flexible conduit | on ElectriciansForums
Discuss Connecting rigid conduit to flexible conduit in the UK Electrical Forum area at ElectriciansForums.net
East Yorkshire
Good evening all,
My first posting on this site.
Some advice on the following would be greatly appreciated.
Am I right in thinking that the best way of connecting rigid conduit to flexible conduit is by screwing the gland on the flexible conduit into a female adapter?
Or is it acceptable to glue the flexible conduit into a coupler. I recently tried this method but found that the contractors pack of 20mm flexible conduit from my local wholesalers would not push easily into a coupler without distorting it a little. I did have some other flexible conduit which pushed easily into the conduit and gave a nice tight fit, even though both were said to be 20mm.
Thanks for any help you can offer me
I used to work at a place called Ronbar Factors in Washington. They are manufacturers of flexible conduit and many other items, with contractor packs being their big seller. So, I should be able to give you an expert answer on this. However I can't, because I never paid that much attention to them TBH! Sorry!
I do recall the 10m packs came with 10 flexi glands and 10 locknuts. If, as per Tels post, you ignore the locknut you can screw the gland on to a female adaptor, and the other end of the adaptor goes onto the rigid conduit. Dead easy, and yes you are right in thinking what you thought Chris! As mentioned, the alternative is a bodge..
The coupler and glue is a bodge.
Especially if it's steel! But I keep seeing it done, e.g. nylon conduit pushed into BESA box spouts and supposedly stuck with solvent cement which doesn't work on nylon. It would be handy if the flex conduit makers offered an adaptor with a male UPVC stub that could be solvent-welded directly into a spout. I often go via a BESA box but as most of my work is in metallic containment, that's just a matter of screwing in a male flex conduit adaptor.
Reply to Connecting rigid conduit to flexible conduit in the UK Electrical Forum area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
To be honest I am in NC and I’ve always used old blankets to cover all my well and never had a problem. Much simpler and has worked every winter...
