DanUK
Hi guys. I hope you can help me please?
I need to hook my Tv up to my AV receiver and the only wire that's between the two is a bare speaker wire (red / black). Unfortunately I cannot run any other cables that way due to the way it was plastered back in.
Doing some research it seems it is possible, although not ideal, to add Audio jack (white / red) plugs onto a speaker cable.
I've ordered 2 lots of these from Amazon so I can chop the plugs off and hopefully attach them to the speaker wires: Belkin F3Y116bf1M 1m Portable Y Audio Cable Belkin F3Y116bf1M 1m Portable Y Audio Cable: Amazon.co.uk: Electronics - https://www.amazon.co.uk/dp/B006W95DPU/ref=cm_sw_r_cp_api_66w8yb1G7Z27B
Here's my questions if I may:
1) if I were to chop the ends of the above and strip the wire could I use a terminal block connector to connect them? I.e red speaker wire to the red audio plug wire?
2) would it be better to solder these together?
The terminal connector block I mention is:
3A BLOCK CONNECTOR STRIP for jointing cable 3A BLOCK CONNECTOR STRIP for jointing cable: Amazon.co.uk: DIY & Tools - https://www.amazon.co.uk/dp/B003ZWE7HW/ref=cm_sw_r_cp_api_V8w8ybM30MK8G
Just to also mention there is only one speaker cable so hopefully the red wire can hook up to one, and the black to the other?
Thanks in advance!
Thanks in advance!
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
