Connecting three wires to a socket | on ElectriciansForums
Discuss Connecting three wires to a socket in the UK Electrical Forum area at ElectriciansForums.net
G
Garethb
Hi all,
I'm in the process of changing the sockets in my house (just the face plates) and I'm having serious trouble fitting the ones with three wires where there's a spur.
Can I just crimp the three wires together and then one wire out the other end to connect? If not any advice please to try and save some of my dignity whilst trying to change sockets?!?!
Many thanks
Gareth
a 35mm back box might make thye job easier. don't forget, only 1 socket allowed on an unfused spur ( assuming it's a RFC on a 32A MCB.)
Thanks for quick responses all!
The cables are 2.5mm twin earth (very newly installed. The fixture has a 35mm back box already. I've no idea how the person who fitted the pr oohs so met did it as I've tried refitting the original sockets to no avail (wires are loose still)
Cheers
Make sure you undo the socket screw terminals all the way to give you enough room to get the three cores in, and put the first two in side by side then slide the third on top in between the two in the grove then tighten down adequately, then do a little pull tet to make sure there tight, jobs a gud un.
Sorry just to clarify, crimping the three wires together isn't an option?Thanks
definitely not. If you are struggling to get a tight connection on the terminals, you will no way be able to produce a satisfactory joint in the back of this socket.
Loose wires can lead to hot sparky crispy bits that can cause fires. Pride comes before a fall, so swallow yours, put your safety before your pride and get a sparky in to sort it for you.
It's not gonna be expensive and you won't get judged.
I have. I wasn't suggesting he should twist them, merely enquiring if he had.
It seems to be a common DIYer trait, which may explain his difficulty in inserting the conductors in the terminal.
Reply to Connecting three wires to a socket in the UK Electrical Forum area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
I think I've found the answers to my questions... I can just do a straight forward wiring i.e. connect the 3 wires from the armoured cable to...
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
