Connection of 2 convector heaters using armoured cable on a radial circuit | Page 3 | on ElectriciansForums
Discuss Connection of 2 convector heaters using armoured cable on a radial circuit in the UK Electrical Forum area at ElectriciansForums.net
Evening Gents,
Im looking for some advice, I have to connect two convector heaters on a radial circuit - I will be connecting each outlet via fused spur flex outlet, I was going to use a 3x3 adaptable box to terminate the one armoured then connect in singles to fused spur outlet and then back through adaptable box to armoured serving other heater- would this be ok?
Sparky 63
To be fair darkwood, as much as I will help someone genuinely trying. If he has the qualifications he is stating, this should be a walk in the park.
It was the theme of half of my posts to show his calcs and help himself ... but yes im getting stalled now if we don;t see any response which shows he's actually working it out for himself then im out of here... i like to help but i aint no mug...:thinking:
Very confusing, as the original question said ONE radial, then seemed to expand later on in the thread! Be interested to see your volt drop calcs though - might as well see it through now. Daz
Reply to Connection of 2 convector heaters using armoured cable on a radial circuit in the UK Electrical Forum area at ElectriciansForums.net
I think I've found the answers to my questions... I can just do a straight forward wiring i.e. connect the 3 wires from the armoured cable to...
Thanks for the input guys. Lighting track is out of the question. The routing (h section guirders and angle iron) means that swa cable clipped...
