Connector for outdoor floodlight | on ElectriciansForums
Discuss Connector for outdoor floodlight in the UK Electrical Forum area at ElectriciansForums.net
Baku, Azerbaijan
I have some outdoor floodlights at home in Azerbaijan, which need replacing. The way they are connected is in the photos - cable through the stone base then up into a waterproof box through a gland.
The problem is that the newer model floodlights that I can buy have much shorter cables - barely 6". And if I take the back off the light, the power cable is soldered to a PCB, unlike the last ones where I could and did change the cable for a longer one.
It seems to me that I need to join the cable underneath the stone base before it goes into the gland. So what are my options for a safe connection? The local method would be PVC tape!
I can get Waco connectors here but anything more esoteric probably not.
[ElectriciansForums.net] Connector for outdoor floodlight[ElectriciansForums.net] Connector for outdoor floodlight
One step up from PVC tape is the self-amalgamating sort. Basically it is like rubber but when it is against itself it slowly moulds in to itself:
It is pretty resistant to heat, water and UV light. Usually you wrap it around, pulling a little, and then hold the tail tight for 30 seconds or so until it seems stuck.
But as freddo has already said, soldering a new iwre is an option - you should practice on something else first though!
I'm with freddo here. diss. the existing flex from the PCB and resolder a longer length while the iron is still burning your pinkies.
Hmmm...sounds like I have to test my soldering skills. Used to be OK about 30 years ago!
Thanks guys
just swig a half pint of Jack Daniels. nerves steady as a rock then, even better than 30 years ago. :) :)
Is there space inside the floodlamp back for a joint? You might be able to use the exiting wire and something like this:
It is usually cheap and easy to get that sort of thing for car electrics, but if you can possibly afford it get a ratchet tool as the simple pliers-type don't give such reliable joints.
Is there space in the floodlamp back for a joint? You might be able to use the exiting wire and something like this:
crimp-butt-splice-terminals
Not sure, I've only looked at the lights in the shop so far. There would need to be space for three though, with the newer LED lights I suspect not.
I use these quite a lot (before Waco was available here), most of my house lights are connected with them so I do have a ratchet tool.
i still got my Weller 100watt from back in the 70's . it fixed hundreds of the early CRT televisions, some with valves. if no new tip available when needed, a bit of 2.5mm stripped out of T/E and bent to suit, made do for a few days. the iron has had 40 new tips and a new silicon flex, but it's still my iron. like Trigger's broom.
View attachment 57548View attachment 57549
[automerge]1587565285[/automerge]
Here's mine. (Not actually mine in the picture. Just couldn't be bothered taking a pic).
  • [ElectriciansForums.net] Connector for outdoor floodlight
Reply to Connector for outdoor floodlight in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
