Consumer Unit Change - Forms | on ElectriciansForums
Discuss Consumer Unit Change - Forms in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
s1m0n
Hi,
I need some clarification,
When changing a consumer unit only,
the forms to be filled in are electrical installation certificate, schedule of test results, and schedule of inspections,
my question is on the Schedule of inspection - that will only be with regards to the consumer unit installation its self, rather than any other part of the existing installation,
I will be doing a PIR before hand on the house,
thanks in advance
That is correct, but you would still need to check bonding etc., is in place and if not rectify it along with the board change. See reg 131.8.... :)
Reply to Consumer Unit Change - Forms in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Personally, I would take a Ze measurement myself rather than rely on someone else's maybe drive by scrap of paper.
2 3
Sockets will probably be ok on one, a little inconvenient in the event of a fault though, I'd probably like a 7th rcbo in. Wonder if hes linked...
7K
suffolkspark
