Consumer unit change | on ElectriciansForums
Discuss Consumer unit change in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Cadgey123
London
I have been asked to change the consumer unit in a clients house and I am looking for any suggestions and ideas to what I should/can do?
The easiest option is to change the MCBS and install a main switch and RCD protection. NOT sure if this would comply with AMD 3 though??
Or I could get the supply company to move the meter and try and fit a new C.U in the space provided, but not keen on joining cables all the existing cables etc.
There is an enclosure sunk in the wall ( previous council flat )
The picture is attached.
Appreciate your experiences or opinions
[ElectriciansForums.net] Consumer unit change
That really isn't a straight forward task, never seen a Wylex NB mantle board. From your post comments I think you need to consult an electrician.
I dont think they are standard i dont do much domestic, measure the old one up and see whats available, they are called skeleton units
Reply to Consumer unit change in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
