Consumer unit change | Page 2 | on ElectriciansForums
Discuss Consumer unit change in the Australia area at ElectriciansForums.net
N
Naz
If no supllier cut off is available, what are the safe methods of isolation prior to changing out the CU?
1. Get supplier to install a cut off switch (could take 3 mnths) or
2. Pull 100A fuse and say security tag was already cut? Regs state work to be done on isolated circuit.
regards
Naz
Iv recently bought a private house which use to be a council property so the meter is outside in White box so they only way to isolate is by cutting the seals but seeing as I am doing a board change don't I need to upgrade the tails
Theres no need to post the same question again and again.....people will see it and respond if they wish.;)
Reply to Consumer unit change in the Australia area at ElectriciansForums.net
