N
Naz
hi all,
can u suggest best way forward, changing out an old wylex fuse box to new split load board, the premises has 40+ old wiring, red and black conductors, the lighting circuits are 2 core with no cpc cable. Under current regs do I need to rewire the property or can i connect original wiring to the new board bearing in mind that I am improving the situation with new breakers and rcd's.
regards
regards
