Consumer unit change | on ElectriciansForums
Discuss Consumer unit change in the UK Electrical Forum area at ElectriciansForums.net
Im confused
You are a PartPee sparks and are asking if you can do work under PartPee
[ElectriciansForums.net] Consumer unit change
I think it has been said many times before, Part P isn't an actual electrical qualification it is one part of the building regulations. The courses that allude to Part P is a course that will potentially equip you to pass one of the certification scheme assessments. You will need to be a member of one of these schemes to notify a consumer unit or or, as MarkyD said, get local Building control involved at the earliest opportunity.
I always think that there will potentially be house insurance issues too if the job hasn't been notified to the appropriate people.
Reply to Consumer unit change in the UK Electrical Forum area at ElectriciansForums.net
Google says that North Walney is in the Lake District? Have we moved the wall :)
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
