Consumer unit heights and mains tailsnew build | on ElectriciansForums
Discuss Consumer unit heights and mains tailsnew build in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
liverpool
are the consumer unit heights for a new build 1350mm and 1450mm.
The services to the new build property will be on the front outside wall of the house meaning the tails will have to be passed through the cavity wall. Can I pass the tails up through the cavity wall to a reasonable height and poke it into the back of the CU box. Or if anyone has a good idea or experience where the services are on the outside wall and route the mains tails to the inside of the property. Again this is a new build
Thanks guys
Is it not marked on the plans?
Reply to Consumer unit heights and mains tailsnew build in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for the replies, I appreciate it.
Sockets will probably be ok on one, a little inconvenient in the event of a fault though, I'd probably like a 7th rcbo in. Wonder if hes linked...
7K
suffolkspark
