Consumer unit in a shower room! | on ElectriciansForums
Discuss Consumer unit in a shower room! in the UK Electrical Forum area at ElectriciansForums.net
Midlands
Renovating a house at the moment and the mains position and consumer unit was in a little toilet room. It is now being turned into a shower room and cost to move meter is too much for the client.
It is just out of zone 2 but obviously still needs a boxing in of some description. What degree of protection is required for it....?
Cheers
Rob
not the best idea. steamy shower + improper ventilation = condensation drops. water and electricity do not mix very well.
if you have to then fit a ip rated enclosure around the meter and service head and get the consumer side tails out of there.
Reply to Consumer unit in a shower room! in the UK Electrical Forum area at ElectriciansForums.net
IMO Better to do something about those ignoring regulations first! Current system is like having a speed limit but not enforcing anyone without a...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
