Consumer Unit replacement cables not long enough. | on ElectriciansForums
Discuss Consumer Unit replacement cables not long enough. in the UK Electrical Forum area at ElectriciansForums.net
FatAlan
Trainee
Nearly Esteemed
Supporter
Surrey
Ok, so you have a motley collection of old BS3036 fuse boxes that need to be replaced by a new consumer unit. Existing installation tests all good but the T&E coming out of the wall is spread out and not long enough. What do folks do to extend cables or what’s the recognised best practice to ensure a neat and compliant job? Any pics?
Obsolete VOLED and no RCD. Was on a TT with very high Ze. Couldn’t locate the earth rod and suspect it’s burried under old extension. DNO has now put in a PME connection and Zs now good.
[ElectriciansForums.net] Consumer Unit replacement cables not long enough.
Reckon the top box will be ok but the three circuits from below could be extended. Just looking for views on seperate enclosure, and connections really. Extending initial legs not option as classic case of client having loads of work and decorating done without thinking about the electrics until too late :rolleyes:
For only four cables needing to be extended upward I would just put a junction box on the wall at the point of the lower consumer unit and push fit wire connector the cables upward to a new CU at the MEM board position. It hardly justifies the use of a DIN rail enclosure, though it would be neat.
Reply to Consumer Unit replacement cables not long enough. in the UK Electrical Forum area at ElectriciansForums.net
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
OP - is this T&E run on the surface or in conduit all the way? Or is any of it below the surface? I'm guessing not as you were talking about...
