Consumer Unit replacement, suppliers fuse, old cable colours etc. | on ElectriciansForums
Discuss Consumer Unit replacement, suppliers fuse, old cable colours etc. in the UK Electrical Forum area at ElectriciansForums.net
R
redlitchfield
Hi,
It's my first day on the forum and thought I'd kick off with a few questions.
I've got my first consumer unit replacement to do in the next couple of weeks and would like to clarify a few points.
Here is a photo of the original fuse board:
[ElectriciansForums.net] Consumer Unit replacement, suppliers fuse, old cable colours etc.
- As I didn't do the original install (40 odd years ago) am I permitted to do the inspection, testing and certification even though I have yet to do my 2395. I am using this job for my NAPIT assesment.
- The cables coming in are old red and black cables and I will be running new circuits in for a kitchen extension soon. Will I need to just use the "Warning, wiring to different versions of BS 7671..." sticker on the new consumer unit or replace the old cables.
Thanks,
Red
The first job to do here is a thorough I&T of the installation so you know what to expect when you install your shiny new CU. I believe that NAPIT will let you notify the job after you have been accepted by them but other lads will tell you better than me
After reading through your post again I see you're asking whether to fit a mixed colour wiring sticker or replace the old wiring. The latter course of action would mean a full rewire and if it's not necessary don't try to sell it to your customer.
Only your I&T will reveal whether a rewire is needed, unless of course the insulation on the old cables starts to crumble in your hands.
Careful now:)
I don't understand your bit about "Am I allowed to do XXXXX". It's your job it's your call and as long as it's done safely and notified properly afterwards.......
yeah mate you have to i&t YOUR WORK
and then notify through whoever you chose but make sure its within days of completion so you can then have the necessarry time to notify to labc within 30 days i think really LABC should be told first but in the real world register do the job and cert within a few days of the registration when passed notify unofficially of course good luck
You will need 3 stickers altogether on your new consumer unit. Just make sure you are really happy with everything that is required of this job before putting it forward for assessment. It sounds like you are not too sure, and that is a little worrying as afterwards you will be let-loose on the general public :)
Go for a full EICR, it will let you know the state of the wiring and is also good practise, better than working on sterile circuits in a classroom. Let us know how many spurs off a spur off a spur you find... :lol:
Testing will also help identify probable faults which will trip an RCD, borrowed neutrals etc. You can also plan what board you want to use and what protective devices you need, leaving a couple of spare ways for future expansion.
Don't forget to check bonding and tails etc. No doubt they'll need upgrading.
Don't be afraid to use the knowledge on this forum, there's a wealth of it.
Most of all enjoy, it's good to get into the real world.
Thanks for everybody's responses so far. Yeah that's why I finally joined the forum and popped my first post up here because every time I've had a look on here for something in the past I've pretty much found it with several different and valid opinions. The customer has already told me he's added spurs in the past, so yeah he's probably spurred off a spur off a spur already!
It's not that I'm unsure I'm just thorough, cautious and very aware that I'm dealing with something that kills. It still frightens me for a split second even after proving my voltage indicator that when I touch those terminals etc it's only the plastic handles and cable protecting me! I'm sure that can only be a good approach, rather than complacency!
Another sticker if the lighting has no cpc..
I know of a ccu change for a guy's NAPIT assessment. He didn't add a 10mm for exposed structural steel or incoming water.. He even did the plumbing in copper... A Electrical Trainee kitchen fitter. :confused: waloc
Good luck
First of all - Welcome
NAPIT will allow you to sign this job off after you pass the assessment - this is exactly what I did
Any problems talk to Helen or one of the girls in sales - they are great
There is no need to inform LABC as your registering with NAPIT, they will just charge you for inspecting it when you can do this for free (using one of your free 5 credits)
Make sure you have all your paperwork up-to-date and certs done as thats one thing they check.
Just to let you know you wont fail the NAPIT Assessment - if they think you are cause for concern they will go through it all with you to make sure that you know what your doing.
The NAPIT assessor (in Wales) is down to earth and a very decent bloke, so hope they are all like him!
Good Luck!
Hi Nicholas,
Yeah the NAPIT sales people have been great, they don't seem to try and push for the hard sell constantly and just want to help.
I just need to go back today, give the original installation a thorough going over, check the main bonding etc and take it from there.
I just need to try and get hold of somebody at Southern Electric now and find out how to organise getting the main fuse removed. Is there usually a charge for this? Also, would they come out in the morning to take it out and then come back later in the day to put it back and re-seal it?
Cheers,
Red
Reply to Consumer Unit replacement, suppliers fuse, old cable colours etc. in the UK Electrical Forum area at ElectriciansForums.net
I would hazard a guess your electrician may be able to contact your DNO and have the switch swapped to a MFS very quickly..
2 3
