Discuss Consumer Unit selection in the UK Electrical Forum area at ElectriciansForums.net
Yeah I need to research a skelton board I think. There's a lot of these mantel units in my area. I've seen a few plastic CU's fit snugly in them though and look neat enough.
- - - Updated - - -
So with these skeltons you just retrofit a suitable model and then cut fit a cover to slide over the top?
Anyone you like, or a skip even, have you got a picture of the whole thing?Any River?
It wouldn't be a problem fitting a board inside that enclosure, the first problem for the OP is repairing the damage to the left hand side of it where it is bent, however that should be doable, I would have liked to see a picture of the whole enclosure, it may be worth taking it off throwing it in the river and installing a board neatly onto the conduits with the meter and tails on show like virtually every other house in the UK LOL
The DNO (or rather the old electricity board) in Essex took a dim view of mounting a normal CU enclosure in those old council Mantel cabinets, to the point of requiring them to be removed. You had two choices basically, installing a normal CU directly above (externally) the mantel cabinet or install a retro skeleton board.
Why exactly would a DNO object and require a normal CU to be removed? And is (was?) that a common stance, or just one particular area?
While I agree a skeleton board might be the best option, if a normal CU is installed well clear of the incoming supply cable, fuse and meter (which are normally near the bottom), why should they object? The top part of the cupboard was designed for the distribution board, just it might now be inside a metal (or plastic) enclosure.
I can only go by experience of the local stand where i used to live in the UK. It was always reserved for the DNO's use, i guess the same as are the modern external meter cabinets!! As i say i've known them to require a retro fitted full CU mounted within the mantel cabinet to be removed and located outside, normally directly above the cabinet....
Personally i can't see the point of not using the made for purpose skeleton boards they are just so easy to replace the old original Wylex/MEM 3036 skeletons.... As i remember the tails and earthing/bonding conductors from the meter/MET to the skeleton board were routed via a built in trunking at the side of the cabinet
The central area is mainly taken up by the DNO's fire proof meter board, that i would imagine would need cutting down thus disturbing the DNO's installation. They did allow a tails isolator to be fitted on their boarding. ...What goes on nowadays i have no idea!! ...lol!!
Reply to Consumer Unit selection in the UK Electrical Forum area at ElectriciansForums.net
