Discuss Consumer Unit selection in the UK Electrical Forum area at ElectriciansForums.net
and check out the other one he has put up...in another thread in here about dis-boards...And WHY would you have done that??
just no need to for it whatsoever....
something about an RCD mainswitch to feed all 8 ways.....as `needs must`.....lol..
have you checked that cable to see if theres a CPC present in it?One circuit is a problem and I've been fiddling about for over 9 hours so far finding various faults, the latest one from where the kitchen fitters went through one of the ring legs (buried unprotected, 20mm from the surface). MCB is continually going on that, not RCD. Most tested, surprisingly, at 4-5Mohm.
She is my mate's mother in law, 70-80, and has no intention of getting the place rewired, he wanted me to put a board in with rcd protection though, and he's done a lot of cheap tiling and plumbing jobs for me so couldn't really refuse.
has kev kitchen caught a cable with a screw?...and it moves slightly when someone leans on one of the units...or worktop?...
OK...Already found one screw through a cable (wall unit feeding socket which dishwasher uses but that's isolated, well one of the cables is), the worktop is a very good point though because it's going quite often when people are in the kitchen.
Just one of those hard situations where I keep leaving with it working, and it then goes again.
so it aint just kev then is it...Not as far as I know, but it's not always easy getting information out of people, especially the elderly. Last time I had a fault with the mcb going this way, it was a downstairs lighting cable trapped between a heating pipe and the upstairs floor boards. All laminate flooring upstairs though so I would hope it's not something similar!
OK...
well theres your first clue then...
so...now we start to narrow it down....
if it were me i would be having a lean & tug on them units...and the worktop...
have a good tramp about on the floor as well...
seems like auld wetpants has put in an appearance as well...
just IR test between the pipework and the neutral....The kitchen and the immersion heater cupboard above are the two areas I'm concentrating on. That's where the faults seem to keep appearing. I'll no doubt find a couple more next time I search, hopefully one of those will be the final one.
Reply to Consumer Unit selection in the UK Electrical Forum area at ElectriciansForums.net
