Evening all, I’d appreciate your opinions here:
I’m looking at an old (150 years+) stone house. Complete rewire and renovation. DNO fuse is currently where the master bedroom will be (upstairs). Client wants it to be moved to a more accessible location downstairs about 15m away depending on the routing of cable.
The timescale for DNO to move their supply and make my life easier is too great so to be avoided if theres any other option.
So the plan is DNO fuse -> meter tails (1m long) -> 100mA Type S RCD (100A) -> SWA (15m x 3c25mm)-> new CU.
Perhaps I can get away with a main switch instead of Type S RCD if tails are properly protected.
Conveniently (or not) there is an earth rod pit on the other side of the wall to where he wants the new CU.
This means I can fairly easily install the MET next to the new CU and bond the CU and incoming SWA to that.
All ccts from CU will be RCBO protected radials.
Any thoughts on this?
What about fitting backboxes to old stone? Its going to be an absolute nightmare to drill, thankfully he plans to dot and dab so no chasing needed.
