Consumer unit upgrade | on ElectriciansForums
Discuss Consumer unit upgrade in the Australia area at ElectriciansForums.net
Steve D
Hi All,
I'm just upgrading my own consumer unit at home - to be honest it's the first bit of work I've done in a while since passing my 2391.
I'm going to be using the job as one of my elecsa membership jobs.
I'm wanting to install an isolating switch in between my meter and cu for future ease, but what sort of switch is normally used for this? The switches I generally come across are the rotary type (although my experience tends to be commercial-biased) but is this the right type?
Can anyone point me in the right direction (maybe with a link to a pic) to the sort of isolator generally used.
Steve
Can I just ask, if there is no existing switch, how are you planning on isolating the supply to enable you to replace the CU? Or do you have a switch between the service head and the meter?
I'm asking because I am in a similar situation, and there is no isolation switch between either the service head and meter or the meter and current CU.
I had assumed that I would need to get the DNO to come in and install a switch for me, before I could proceed with a CU upgrade?
Cheers
my best mate is a meter fitter, and installing isolators is a job he gets called out to do. He does this either because the customers has requested it, or in the case of new builds, to install a supply before the installation is wired, and therefore there is no CU in place.
no but those Sper Sparks cut and reseal Legaly without autherisation you are breaking the law and as the OP is using it for his assesment a missing seal might not create the best impression
The only difference is that the meter fitters wear a live working glove (big white rubber thing) and then reseal it. They wear the glove because old fuse carriers can and do crumble sometimes when removed (my meter fitter friends experience)
The one who replaced my ancient cut-out (see my other recent thread on here somewhere) certainly didn't.
No gloves, no face shield, nothing.
He snipped the live fuse wire (no fuse holder - just wire) with his pliers. He didn't even turn the consumer unit off to remove load.
I was watching him working the cable like it was a venomous snake - dodging his hand and arms as he removed the old tape from the live ends.
Reply to Consumer unit upgrade in the Australia area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
