Consumer unit | on ElectriciansForums
Discuss Consumer unit in the Australia area at ElectriciansForums.net
R
rob69
Hello All,
I have got to replace a consumer unit but due to the very limited cable lengths these will have to be extended.....Is crimping ok or what else could you recommend to comply with the 17th edition??????
Thanks Rob
crimping is ok. crimp them with a bit of heat shrink over the top and put the cable in trunking out the way. You can also use jb's but they don't look to good. Its up to you.
Hi Kduck and Patrick,
Ok thanks just wanted to be sure.Just one last thing , i take it the current rating of crimps is a consideration , so can you suggest manufacturers or suppliers !
Cheers Rob
most wholesalers will have box sets of mixed smaller sizes ie 1.5, 2.5 etc. make a note of what size cables you have or trim off a sample and show the supplier. try and spend a few quid on better than cheapest crimper you'll be glad of it too the basic ones can twist up and be harder to work with
fair play kduck is already there
Reply to Consumer unit in the Australia area at ElectriciansForums.net
My understanding is it's not necessary unless compromising a fire barrier. Hager instructions: Cable Access: Cable access into the metal...
