Consumer unit | on ElectriciansForums
Discuss Consumer unit in the DIY Electrical Advice area at ElectriciansForums.net
suhel_a
London
Hi,
I have been living in my new house for about a year. I checked inside my consumer unit (fuse box) and took a photo. I am not sure if everything looks okay, especially the busbar. The circuit breakers seem a bit misaligned. Could someone with more electrical knowledge take a look and tell me if everything is safe?
[ElectriciansForums.net] Consumer unit
Hi,
Could do with tidying up, difficult to say if something is safe from a picture.
The only problem I can see is someone has taken the front cover off 😁
I wouldn’t even say this is untidy… about the normal standard really.
If anything, there appears to be a badly terminated armoured cable coming in the bottom.
The black core of that, I think, is terminated into the earth bar at the far end… it should be identified as an earth core with green/yellow tape or sleeving.
The grey of the same cable, I presume, has been wrapped in black tape, because I can’t see it.
The brown is the 20A at the far end?
MK brand is known to have a “lean” where the breakers don’t sit straight.
there is 2 exposed pins of the busbar at the far end, which I hope have corresponding blanks fitted into the cover when it is on.
Now, unless there is an isolator on the incoming tails which is switched off, you shouldn’t be taking the cover off… it’s exposing live parts.
Is there an issue with the installation that prompted you to remove the cover?
Hi,
Thank you for the reply.
I have just had an isolation switch installed and was intrigued to see how my consumer unit it is terminated without the isolation switch I would have never opened the cover.
I thought it was a bit messy but as long as it’s safe I am okay with that.
Just a few observations that caught my attention.
1. When the cover is on, the main switch has a gap on the left side about 1cm. Looks like it needs to be shifted to the left a bit.
2. The circuit breakers are not aligned and seems thy all need to be shifted.
3. I am no expert which is why I would like some advice but is the busbar terminated correctly. When looking through numerous installs online most installs have the busbar on the main switch but mine does not.
It would be a peace of mind for me if someone can assure me all is safe.
Many thanks
The busbar is wired correctly for a dual rcd board.
The silver DIN rail it is all mounted on has two notches to the left of the main switch, the switch should be up against that then you would have no gap.
So move the main switch left up to the notches and all the circuit breakers to the left to close the gap. Thank you, as long as I know its safe its all good. I will get an electrician sometime in the future to have a look at that and correct it.
Many Thanks
In need of attention, or at least closer inspection, 'badly terminated' IMHO.
What is this cable for?
The armoured cable is being run to my outbuilding, from your reaction I take it its not the best termination and should redone?
Can't see clearly in your pics, but it appears that the wrong type of gland has been used and that gland is too small for the hole in the CU that it's in.
Yes that does appear to be the case. I may get an electrician to fit the correct glands.
Thank you.
Reply to Consumer unit in the DIY Electrical Advice area at ElectriciansForums.net
Could have easily moved the isolator to the side of the meter, shortened the tails, and managed to find a grommet/gland for the CU.
I saw some videos talking about RCD's and RCBO's which is what got me curious and to realise how outdated our CU is. I think going forward I'm...
