consumer units | on ElectriciansForums
Discuss consumer units in the DIY Electrical Advice area at ElectriciansForums.net
davetoms
Hi, i am having my consumer unit replaced in the house, and a new consumer unit in the garage for lights and sockets.
I have had a couple of electricians come out and look at the job, but they both say conflicting things about how the job needs to be done, so i would like some advice about which one of them is correct.
The first bone of contention is the house consumer unit. Currently is located in the cupboard under the stairs. One of the electricians says for it to be updated to a new board it has to be moved, as under the stairs isn't allowed anymore. While the other electrician says as it is a replacement/upgrade it can be stay under the stairs, because it would be a big job and expensive to move it elsewhere.
Which is correct? Ideally it would be able to stay where it is.
The second bone of contention is the new consumer unit going in the garage. The first electrician says the new consumer unit can't be located to close to the wall, i think he said it had to be at least 400mm away from the corner of the wall (which seems a bit odd to me).
The second electrician says the new consumer unit can go where ever i want with the only limitations being height restrictions, essentially it can be fitted right in the corner nearly butted up against the wall which is where the supply cable enters the garage.
Which is correct?
Consumer unit can remain under the stairs. As from 1 Jan next year, it will generally have to be a new-style metal one to the latest edition of the regs.
Consumer unit can go close to a corner, providing that access is adequate. It would be interesting to find out why the first electrician said no.
Seems that No.1 doesn't know what he's talking about.
I don't know but you might find some guidance in Part M saying it should be 400mm away maybe, just a guess.
Could be. Sounds like electrician 1 is getting confused and applying requirements that aren't applicable to this situation.
Reply to consumer units in the DIY Electrical Advice area at ElectriciansForums.net
thank you it really made me feel small, maybe i played it a bit thick, but as the one needing the work done i was cap in hand, will try another...
I have ascertained that I can have a fuse wire type consumer unit provided it passes the EICR tests and also that it can be in a waterproof...
