B
benwill87
Hi all. Is it now regulations to fit a cu with every circuit protected by an RCD? or can you still install split laods?
Discuss consumer units in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Fire detection circuits must be supplied independently of other circuits and not protected by an Rcd protecting multiple circuits. 560.7.1 so if any smoke alarms in the main rcd would be no use too bald sparkies correct rcbo on seperate circuits what be better allthough alot more cost.
Reply to consumer units in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
