contactor for underfloor heating | Page 3 | on ElectriciansForums
Discuss contactor for underfloor heating in the UK Electrical Forum area at ElectriciansForums.net
B
bennjy
Hi
I've installed the electrics for an underfloor heating system. The system has 6 manifolds each with a small pump. There is then a primary pump that pushes hot water through the system from an aerobic digester next door. I have fitted 6 contactor each using a switch wire from the thermostat to energise terminal 1 of the contactor, I have then linked from terminal one to a of the coil. I've taken a neutral to all contactor in parrelal in terminal 2 then from 2 to a2 of each contactor. I've then connected in parrelal the primary pump to terminals 3 and 4. This works fine with one stat, when it calls for heat aswell as energising the secondary manifold pump it also energises the contactor and energises the primary pump. The problem is, is that when another stat calls for heat if the other stat goes off the contactor still stays energised until all stats are off. I don't think it's latching contactor I'm sure there non latching could be wrong tho. I'm sure it's a wiring fault so any help would be great .
Yes naturelly you will have backfeed from any of the 6 when calling, but this won't hold the contractor closed. Only the coil can do that.
According to your opening post you linked 1 to a1 also, this is your problem.
Reply to contactor for underfloor heating in the UK Electrical Forum area at ElectriciansForums.net
Update... I wired up my first heating system today! Thanks to all the help in this thread, (and the initial thread) I was completely prepared...
I think it was too early yes I meant 3 not 2, but great I'll give that a whirl and thanks.
