Contactum CU | on ElectriciansForums
Discuss Contactum CU in the UK Electrical Forum area at ElectriciansForums.net
Andover
Hi people, new to this forum.
just went to do an EICR and the upstairs lights aren’t RCD protected. Rather than fail it and say it needs a board change, I’d like to the circuit on an RCBO.
The Consumer Unit is an older style Emma/Contactum board. Am I right in thinking a new miniature Wylex RCBO will fit in there? There is a circuit on a Wylex MCB, so that’s why I’m thinking it will fit.
Just wanted some advice before I go and source the RCBO.
Thanks in advance
Why would it 'fail' and EICR? I would only code that a C3 which would still attract a satisfactory report. If a special location is fed from part of the circuit then I would look at the existing lighting within the location and check that supplementary bonding is in place, if all is good then no C2.
The Wylex device should not be there so needs Coding. Contactum produce compact rcbos.
Agree, westy...but if the RCBO won't fit in the older CU, would you reckon it's still a C3 for no circuit rcd......... and the Wylex cb still in place? ?
Do two C3's add up to a C2??...or a C6??
Thanks in advance
Hello. Alan here from contactum technical support. Could you please let me have a part number from one of the Contactum MCBs within this board. Ill then be able to assist you further. please email me at [email protected]. Kind Regards Alan Broom TMIET
Reply to Contactum CU in the UK Electrical Forum area at ElectriciansForums.net
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
