Contactum MCB | on ElectriciansForums
Discuss Contactum MCB in the UK Electrical Forum area at ElectriciansForums.net
East Kent
Hi, I will be upgrading a shower shortly. The existing unit is 7kW and I'm fitting a 9kW unit. Does anyone know where I can obtain a Contactum 40A MCB from. I can't find any supplier that stock the type on the photo (9040B). Or is there an equivalent that fits this CU ? (Contactum P12/80N) [ElectriciansForums.net] Contactum MCB
Thanks Durhamsparky, I tried TLC online and they've got one! BTW I will be upgrading cable to 10mm*. Another quick question is why do so many people seem to fit a separate shower consumer unit? Is it just due to lack of capacity /RCD?
normally due to the fact people don't have RCD protection on the current CU (probably a old wylex 5/6way db or it was fitted by a monkey and he saw the sign in B&Q say "shower fuse box" complete with 50A MCB
also works nicely for the "garage consumer units" FFS!!!
Reply to Contactum MCB in the UK Electrical Forum area at ElectriciansForums.net
Hi Steve. Thank you for this, sorry, i should have searched the forum before posting.
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
