Continuity check?? | Page 3 | on ElectriciansForums
Discuss Continuity check?? in the Australia area at ElectriciansForums.net
Arsenal(London)UK
:confused:Hi guys,
Could anyone educate me as I'm no way near as good as ok..!
Had a problem which I've previously posted on your forum, about GU10 downlights, my question is..
If you were to be doing a connection check on the terminal strip of the downlight( earth to common earth to live )?
What reading would you get (open or closed)???:eek:
hi mate
all the members would not want to risk giving you info as you are a bit out your depth
brown is the line conductor and if its running from switch this is a sw/line and is a live conductor
blue is the neutral also a live conductor
green /yellow is the cpc (earth)
as for continuity
with the test leads of your instrument connected together you will get a low resistance ohm reading and this is a closed circuit
a open circuit will as durham says give you a reading of 99.9ohm or greater depending on your tester
ie with test leads not touching each other try it then you may understand
as for telling you how to conect your lights this is because no one wants to accept responsibility if you do it wrong which you already have
to do a continuity test on a lighting circuit there is a lot you would need to understand first and how to carry it out safely in a competent way so to not cause you injury or danger to others
your descriptions are very vague and if you really want to know you would be better getting a copy of the Iee on site guide
your course should teach you how to wire basic lighting circuits properly and how to inspect and test them
what course are you doing
Hi Bruce thanks for response. I think I over exagurated it a bit . There is lighting in the kitchen now and since have installed 6x 12v downlights 50watt with 6x 65watt transformers, and all is fine.
But still can't understand why fuse had kept flipping.
Do you have make advance checks before connecting the live and neutral to GU10 downlights, as there were no instructions???
Thanks again, doing a plumbing course with T4T trade skills. Which involves learning via reading, and submitting se4narios and files for marking. All is good and thanks for a great illustration there.You sound like a good sparky???
And sorry if I'm out of my depths here, but your advise and help made a lotta difference..
Reply to Continuity check?? in the Australia area at ElectriciansForums.net
When I was at college doing the 2361 back in the 1980's I still recall to this day the instructor (Mr Wood) saying "Lads I do not want you to...
