P
Peter88
Hello,
Though qualified I have never actually worked as an electrician. I now have a problem at home.
I have a situation I can't get my head around. Its a partition wall, timber and hollow. The wiring is all inside. On one half I have power, with common working. On the other half I have live phase but no common. I can't find a loose contact. When using a multimeter I get 240 volts on the not working side but only when using earth as common.
Is it normal for earth to complete a circuit like this? Am I right in assuming that coomon is broken somewhere? With earth acting as a common does this suggest its touching somewhere?
You probably would get 240V between line and earth as the earth is combined with the neutral after it has left the property, if it is a TNCS/PME supply.
I think maybe you should enlist the services of a local electrician.
It is very difficult to describe faults on a forum.:)
Continuity problem.
Australia
Peter88,
Peter88,
