Hi, I'm looking for an eyelet connector to put the new wire to ground. It's scarce in my city (not to be found), especially if I want a quality set. Do you think it's important to put certified connectors or it's enough using cheap chinese ones? I'm no expert about it and I'd like to avoid my car being on fire Thank you
Thank you a lot. I don't know what a tug-test is but I'll make sure is firmly crimped.
We get in trouble with a Good yank , or an impulsive jerk !yes that's a UK term sorry!
Thank you. In fact today I tried crimping a few times with random wires just to try and the result was quite good. I only have a wire stripper that is also a crimper, so it won't be a professional result but who cares. I didn't find eyelet connectors of the perfect size but it doesn't matter. Tomorrow I'll do the repair
Do you think it could be a good idea to sand the free ground point (at least I suppose it's a ground point) until it's bare metal? The already occupied one seems to have little room for a new connector. Thanks again
Lithium spray grease? Like in car batteries connectors? ?Wouldn't do any harm yes. Cover it with a bit of grease when you've bolted the terminal up.
I just cut the ground connector's wire and the conductor is damaged. I don't know if it was the wire stripper or it was already like this. Do I have to cut in Another point or can I continue like this even with a reduced copper wire section? Thank you
