Pete999
There has been a lot of debate regarding differing types of Electricians, I have nothing else to do so I thought you would like to read about my sojourn in this trade of ours, if you don't then tough. here goes.
I started as an Apprentice with a small contracting outfit in Bath, in the early 60s 1960s that is for you comedians out in forum land.
Said firm went bust during the building boom and I was transferred to one of the large building consortium's after several years of house bashing, cold building sites and having just got myself engaged to my now Wife ( yes people did get engaged in those days ) Mortgage to pay, I thought ---- this for a game of soldiers, I need a proper job.
I had all my qualifications, and a lot of experience of building sites, and applied for a job as a maintenance Electrician with the then Department f the Environment (D of E) on an RAF base near my home, got the job, but it was a bit of a cultural shock, you see the rest of the Sparkies came to work in a collar and tie, get the picture? and their tools consisted of an old Army bag with a few bits and bobs inside, pliers etc. the hardest thing they did was change a few lamps, I did learn a lot from them though which stood me in good stead for the rest of my working life, I went from there to two overseas postings, and finally a job with the big boys in central Government, I guess what I'm trying to say is, if you get the chance to try different aspects (maintenance and Contracting)of being an Electrician, go for it, I did and it worked out well for me.
Sorry if you find this boring, wait til I publish my book.
A hospital is just a good quality distribution system with a few bits added.
You don’t know how the equipment works. Because of that you can’t fault find on it other than the basics.
What’s your knowledge like on instrumentation, hydraulics and pneumatics?
Could you work on a chemical plant were all the equipment is bespoke. You can’t call anyone in to help out as the only people who know how the process works are the company men.
Could you deal with thermal run away in a process, a major power outage that puts life in danger due to the process becoming unstable, I doubt it.
Can you work on MV switchgear and cables other than just put them in place?
Come on admit it, you’re just a cable monkey. The bain of my life for years!
My name is Aiden, and I'm a cable monkey :-)
Sorry Tony and Eng, I don't agree. Trained money!!!, NO that is not the way, so you think installation Electricians don.t fault find and commission their work. I have worked at many hospital's in me time, and the so called maintenance sparky's were all sitting in their little workshop/ stores drinking tea and changing a few lamps and fittings. (or cleaning). Me at the front end doing the real work.As for factory's production etc, can't say, only that one firm I worked for had the contract for metal box (tin caned factory), maintained the production line, the boys on that said it was a douse. lol
Read my last post above with regards to Hospital maintenance!!
I don't think you have much of a clue when it comes to what a real industrial maintenance electrician is all about. Most need an HNC these days to even get a start. It's always a douse as you call it when everything is working correctly, the problem comes when it stops working and the installation electrician that is sent by the outside contractor to fix it, hasn't got a Scooby doo as to even know where to look, let alone know what's wrong with the plant....
Pete999
Northampton
Retired Electrician
Business Name
None
Contracting versus Maintenance Electricians and on into the future
Pete999,
Engineer54,
