An odd question granted but bear with me.
I've got to extend a radial circuit in a community centre to fit a new hand dryer in the toilets, but I have two restrictions.
1. It's a listed building so I'm not allowed to damage the walls in any way.
2. Even if I could, I've been told there is asbestos in the wall cavities, so I couldn't drill into them anyway.
So, nearby there is a flush mounted single socket on a 20A radial. The easiest way would be to run some nice D-Trunking from that socket around the wall and into the toilet area where I can surface mount a switched fused spur for the hand dryer. Jobs a gooden. However it's a flush mounted socket, so to make a nice neat job I need to convert it to a surface mounted box, so I can neatly fit the trunking to it.
I suppose the first question is can it be done ? Currently in the wall is a 25mm metal back box. If I could find a way to screw a surface mounted box to it, then that solves the problem and I can fill any pasterwork gaps. I suppose I could very carefully drill out the fixing points from the back, that could allow a long fixing screw through the front plate, surface box and into the metal back box, but that seems to be a bit of a faff.
Is there anything on the market designed for this very job ?
